Pulley Weights...
Old 04-28-2005 | 08:20 PM
  #21
Tibbychick's Avatar
$220????
damn, I paid like $100.
I bet its cheaper to go directly through UR.
Old 04-28-2005 | 10:01 PM
  #22
Mad_john's Avatar
dam i did not know that there was that much a weight diffrence... calling UR right now. smile.gif Dam good info ppl B)
Old 04-28-2005 | 10:04 PM
  #23
OdessitPashka's Avatar
Let me know if you get ahold of them TC. I'd definitely get crank pulley if it was under $100. Btw, did you have to change your belts?
Old 04-29-2005 | 01:42 PM
  #24
Tibbychick's Avatar
yeah they had to change the belts, I ended up changing all my belts though, except the timing belt. Actually its funny, I had the car towed to my mechanic, and the guy there went to install the pulley but couldnt figure out where it went. So I had to call him to tell him that it went on the crank and he would need smaller belts.
Ive gotta figure out when I can make time to go over there. I should be able to go the end of next week.
Old 04-29-2005 | 03:04 PM
  #25
krazykyle's Avatar
So, crank pulleys for RD1 and RD2 are both same?
Do you know the sizes for the belts they had to end up using on the new crank pulley?
Old 04-29-2005 | 03:05 PM
  #26
Old 04-29-2005 | 05:40 PM
  #27
QUOTE (Tibbychick @ Apr 29 2005, 02:42 PM)
If he was not somebody you already trusted.. I would be wary of him.
Old 05-05-2005 | 05:25 PM
  #28
Zman's Avatar
A little hijack on the thread, is there a code or part number for the smaller belts you use with the underdrive pulleys?
Old 05-05-2005 | 06:19 PM
  #29
tibbytib's Avatar
I have the entire set of pulleys from OBX for my RD1 and will be installing them in like a week. I will be doing a DIY on this with everything from pics to product numbers. I searched for hours and could not find one soul with the correct sizes or part numbers for the belts. So when I do it and find out EXACTLY what we need, it will all go into the DIY. B)
Old 05-05-2005 | 08:15 PM
  #30
Since TC won't return IM's or respond, I'll let you guys know something.
UR contacted me back. They aren't going to make a accessory pulley line for us, BUT, if we send them the stock pulleys for each setup, they'll give us a quote, and do a run just for us.
Could be a good thing.
Anyone got a set of RD1 and RD2 pulleys sitting around?
