Problems With Car Cutting Out
Old 07-04-2008, 11:46 PM
I didn't when mine went bad. Especially when it started going bad. It was occasional, and annoying.
Old 07-06-2008, 02:02 AM
TibFreak's Avatar
alright, I am going to invest in doing plug/wires like I have been meaning to do, then try the TPS, if plugs/wires don't work, then grab a fuel pump if none of that works.
You guys think thad sounds like the sensible thing to do? Does to me.
Thanks REDZ, I'll keep that in mind($20 shipped, sounds good) Is it new? or......
I am still needing to know how often fuel filter should be changed, like I said, it has been changed once since 2002(about 2-3 years ago)
Thanks All, before you know it, I'll be telling you all how to fix your car.
I will help so many people, I will surpass REDZ on his numbers of posts.
Not really, but its a nice thought i guess.
Old 07-06-2008, 01:33 PM
I wouldn't bother with the fuel pump, go to the DIY section and check out the DIY Test I put in there for the pump.
The TPS I have isn't new, but it's the one you want, a Keifco.
Fuel filters are supposed to be 40,000 miles I think.
