Premuffler
Premuffler
I have a 2000 Kia Spectra, I'm thinking about cutting off the premuffler and putting a flexpipe in it's place so I can get better airflow. Is this a good Idea or will it run like ****??
Right, it looks like this,... comes out of the manifold, into the catalytic converter, which you probably already know, and it has a what looks like a muffler in the middle and a muffler in the back, the one in the middle is the one i want to take off
wink
wink
That could be a second cat, or it could be a muffler/resonator.
Take to to an exhaust shop, they should be able to tell what it is by looking at it.
If it is a resonator/premuffler, all it will do is make your car louder, it won't really increase your HP/torque. You should go with a set of headers, high flow cat, cat back and high flow muffler if you want to make more HP/torque. Just removing that one resonator won't make a great deal of difference.
I would wait and do it all at once. When you go with the headers, a large portion of the exahust will need to be *re*-fabricated. You may end up paying for them to replace the resonator/premuffler with a straight length of pipe, then have to pay them again to lengthen it or shorten it.
