Phantom grip
Arn - Esa no es la manera de tratar a un hermano latino yo soy Puertorriqueno y nuestro primer idioma es el espanol asi que por un simple error no tienes que postear tu estupido mensaje anyways tu entendiste lo que el quiso decir.
Juan Jose-te envie un email contestando tus preguntas.
Ok we know the Tiberons needs a real LSD. So the question is, can we get qualife to make a helical one or what about SharkRacing? I think this is going to be the only thing the tiburons, elantras, and accents need! We have pretty much everything else! The 03 GT tibby is just begging for one!
1) Manual only
2) a lot. www.howthingwork.com www.phantomgrip.com
3) none whatsoever, it will not work
MagusKampodraken:
I'm not sure about the 03GT, but there is one that fits with some modification. Quaife will do the modification for you, but you will loose the warranty from Quaife on the unit. If you modify the unit yourself, you also loose the warranty from Quaife.
Hey Random-
You wouldn't happen to know whether the differental in the 2001 Elantra/2003 Tib I-4 is the same as the 97-01 tib.
Since I'm staying NA the phantomgrip unit sounds like a decent mod. Just wondering if it will fit
