perforated core INTAKE resonator
Has anyone thought about or tired making a resonator for the intake. I realized that more noise actually comes out of my CAI then exhaust so I was thinking about taking the 3in pipe, drilling a bunch of holes in a 8-12in section and putting a piece of 4 inch piping around it with some fiberglass or header wrap in the interior space.
Any comments or suggestions?
ummmm
engine noise rules man
Why would you want to quiet down your intake???
If you really want to quiet down your car,... get a glasspack
I have one for sale,... if your interested private message me
Its a 2.25 perforated core
Well, that explains some of it... the fenderwell probably acts like a great resonator. But it does have good access to cool air.
Some intake systems have enclosures built around the filter to help funnel air in and to reduce the noise. see enclosure
Building an enclosure will take a little work. If you have some fiberglassing experience you could probably build one.
A large part of intake noise is really intake tube vibration.(due to engine vibration and air pulses inducing vibration in the materal)
In my testing, the "noisest" intake tube was thin walled aluminum tubing. It had a VERY loud "snarl" to it, nearly a "buzz"
The quietest intake I tested is the flexable exhaust tubing. The corregations in the flexable exhaust tubing deter vibration.
To quiet your intake down, heat wrap it with the thermal wrap. This dampens the vibration of the metal and seriously quiets it down.
With the CAI in the fenderwell, the sound is indeed "amplified" by the large fenderwell air cavity. The aluminum tube intake actually induced vibration in the sheet metal of the fender, causing IT to vibrate/produce noise.
Also, your choice in air filters affects noise. 100% rubber filters like some K&N filters are not as noisey as some cheaper all metal air filters. (the materals around the filter medium, not the filter medium itself).
The enclosure that Cheuk reccomend would also help, as long as you could mount it in such a way it was isolated from the CAI's vibration.
