Oh ye, one more question.
I was trying to find cat-back which is cheap.
I found this one,from HDK
rear
Mid,
Can you call this cat-back too?
If it is, is that good as the SpeedState people sell?
And is it possible that I get rear from Speed state, and mid from HDK,
Which one is better Speed or Hdk?
rear
Mid,
Mid pipes are more or less all the same, it's the diameter that will make the difference, but you need the diameter to match your muffler, and the flange to match your cat converter.
That mid pipe from HDK looks like it has a 3 bolt flange on the cat converter side of things. To the best of my knowledge, on my car anyway, that is a 2 bolt flange (like the other end)..so you might have to get that welded off, and a 2 bolt flange put in it's place.
[ December 05, 2001: Message edited by: Random ]
