O2 Sensor Question
I got a CEL and the code was for bad oxygen sensors.
I took the car to the mechanic and they changed all the two sensors.
After they replace them, the up stream sensor's reading is bad. the voltage was too low.
I replace the bad sensor and put the new one in, but still have CEL on.
I don't know what cause the problem.
My question is that which sensor goes whree.
there are two sensors that one for the up stream and the other one for the down stream.
they put the down stream one right behind the second CAT and the up stream one behind the header's Y pipe.
Please help me what cause the CEL on.
Thank you.
Thank you.
