New Clutch Problems Please Help
i just got a new act street clutch kit installed in my tibuorn and i also had the flywheel resurfaced. a hyundai dealer did the install so i know it was done right, but i have some clutch chatter that vibrates the steering wheel when i take off of the line. is the shudder possible cause the clutch isnt broken in yet or is something else wrong>> or is the act strreet clutch gonna have a little bit of shudder upon engagement??
something isnt tight enough. i have ACT 6puck and it only made noise when i didnt have it tighten down enough. now that its torqued down right its silent as can be.
how can i tell if i got bad motor or transmision mounts and wouldnt they b able to tell if the tranny monts were bad when i got the clutch. my steering wheel does vibrate when im in neutral but its not a real bad vibratrion but its a vibration still
here is excacly wat happens, i let off the clutch and the steering wheel vibrates
help me pleaz car has 89000 miles on it
maybe i need to give the car more gas with this performance clutch??
