Need Help To Take Out The Ecu
ohhhhhhhhhhh.............I think i going to have to take the ecu out, I going to replace that thing.
i couldnt find anything in webtech.. now I going to check out here, i hope i can find something.
As has been posted. Take off the fuze box cover on the drivers side. That entire panel.
Then, remove the FUSE BOX, takes like 3 bolts.
Then you have a MUCH better shot at the PITA bolts.
Then bolt it back up with only 3 of the 4 bolts.
