Need help plzz....
Re: LED & Speakers...
Wasup guys. Alright im still learin my car stuff so....Over the last few days i have noticed something weird when i shift. When i shift instead of the rpms dropin about 1000 everytime i shift or whatever it is, everyonce in a while when i shift instead of doin that the rpms stay up at the same amount untill the next gear catches up to the rpms and then it starts moving up. I hope that makes sense. Now some1 told me that means my clutch is probably going out.. 02.gif Is that most likely true or can that be something else. Any help would be apreciated. And i take it warranty dont cover clutch??
Thnx guys
Thnx guys
Re: Projector Headlights?????
I say TPS or your throttle cable is getting stuck somewhere, most likely TPS.
I doubt it's your clutch, to check your clutch, go about 60km/h or about 40Mph.
Put it in 5th, and giver gas, if your RPMs go up and you don't accelerate (slowly) then yeah, you'll need a new clutch.
But I really doubt it's your clutch
Re: DIY - REDZMAN's Dual Trunk Light Mod
Welcome to the site mang, Kayjai is right, prolly not your clutch.
Also, make sure you check the ABQ BBQ thread in the MEETS section, you aren't far away, come and meet a bunch of us.
Vehicle: 2015 Subaru WRX
Re: turbulence buttons/knobs for tibs?
I was having a bit of the same problem... check out this thread mang.
http://www.rdtiburon.com/index.php?name=Fo...t=21&highlight=
