Need Help Asap
#21
fing02.gif dont pry it off unscrew it conter clock wise. if you must get you a long flat blade screwdriver and a hammer a gently tap it a few times... also if you dont put the rubber gasket back in correctly you will leak fuel. brother you have the same tank as me we are the KDM spec and not the US spec.. PM me if you need more help
