Need Help Asap
Old 08-02-2005, 04:44 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
At first when I added gas rpm droped end then engine died, just stoped.
So now I spin starter and engine don't start.
I checked all fuses - nothing.
I checked timing belt, seems it's fine.
I thing it could be fuel pump.
What to do? need help.
How to check if it's fuel pump?
Old 08-02-2005, 05:31 AM
javageek's Avatar
I believe you can hear the fuel pump if you turn the car to on and listen by the back seat.
Old 08-02-2005, 05:34 AM
Dmitry's Avatar
I take out rear seat, and when I turn to on there is no sound.
How loud it should be?
Old 08-02-2005, 05:47 AM
JonGTR's Avatar
Load enough to hear it. Take it out and test it.
Old 08-02-2005, 05:53 AM
Dmitry's Avatar
Just tested, there is 12V in the connector but there is no sound from the pump.
How to test pump? pull it out and apply 12V? Does it metter on what terminal to put + and -?
How to take off cover?
how to get that pump out?
I don't see bolts.
there is only connector and 2 tubes.
How to get out that plastic cover?
Old 08-02-2005, 07:48 AM
JonGTR's Avatar
The round black cover? Just pull it off. It's sealed on with black goo.
Here is Brendans DIY on a pump replacement: http://webhome.idirect.com/~trini/car/pump.html
Old 08-02-2005, 07:55 AM
Dmitry's Avatar
crap
I have a cover - here is it:
and I cannot move it
Old 08-02-2005, 07:58 AM
JonGTR's Avatar
There should be screws all around it that allow you to remove the pump assembly.
They're in this pic: http://webhome.idirect.com/~trini/car/pump6.jpg
Old 08-02-2005, 08:09 AM
Dmitry's Avatar
here is mine
http://www.chat.ru/~tiburon100/fp2.jpg
Old 08-02-2005, 08:26 AM
JonGTR's Avatar
Wow, totally different. It looks to me like that is some kind of clamp? Maybe you can pry it off?
I don't know. No one here has a setup like that and this is the first time I've heard of this. Your best bet is to get a service manual and read up.
