Need Help With 2 Cel Codes
i ran the obd scanner on my car and came up with the following:
0141- o2 sensor heater circuit (bank 1 sensor 2)
0446- evap emission control system vent control circuit
does anyone know exactly what these problems are and how to fix them? thanks.
Oxygen Sensor Heater Circuit Malfunction (Bank1, Sensor2)
Evaporative Emission Control System Vent Control Malfunction
I'm betting you have some crud or shorted wires on your ECM connector. It's easy to see that something could be shorting the wires and causing a malfunction, the pins causing faults are pretty close together.
Have you changed your ECU lately?
