My "Top Secret" Ram Air
Old 07-29-2002, 01:14 PM
  #31
Neo_Tib's Avatar
Vehicle: 01 Tiburon
To get the J@WS01 CAI,
I swear ... no frickin respect ... STEVE.
Looks like we have another one
Neo_Tib is offline
Old 07-29-2002, 01:15 PM
  #32
KayJai's Avatar
I figure we need some humor, wink wink wink wink
after today
KayJai is offline
Old 07-29-2002, 09:54 PM
  #33
Emagdnim's Avatar
How did you connect the big tube that connects to your intake(the idle speed controller or whatever its called)?
Emagdnim is offline
Old 07-31-2002, 10:28 AM
  #34
bubbles's Avatar
KayJai:
To get the J@WS01 CAI, wink
You need to make sure there is no Evap Canister in the fenderwell for the 96 Elantras. Since the 97 tibs (A-SPecs) had them there and tibs are based on elantras, I would find that out first before preceeding
Well, so much for that idea. It does have the canister in the fenderwell. I guess I'll just custom make one and have it run down between the battery and trans.
bubbles is offline
Old 07-31-2002, 01:59 PM
  #35
KayJai's Avatar
Yeah, you'll have to make like a AOS type of intake
KayJai is offline
Old 08-01-2002, 09:13 AM
  #36
9o7TiB7o9
There are several problems with the Weapon-R(ice) "ram air" setup.
#1. You need to put that pickup horn in a high pressure location. Only one available is UNDER the front bumper of the car.
#2. That "dryer hose" piping they use is HORRIBLE at air flow. Even if you did ram 100mph air IN, I would bet less than 25mph air would come out the other end.
#3. The "air horn" end attachment is improperly shaped, and is also only 2" inner diameter.
#4. The "ram air" cover that goes over the filter does not seal. Around the outside edge there is a .25" gap between the filter base and the "ram air" cover. If by some fluke you got pressureized air to the filter, it would just rush out the .25" gap around the filter base.
#5. The same .25" gap I was talking about above? It sucks in HOT ENGINE AIR!!! It's much easier for the air to travel 2" up that .25" gap than it is for it to enter the tiny air horn, down 6' of dryer hose, and then into the filter. 90% of your air is coming from the gap around the "ram air" cover. If you don't belive me, block off the "horn" with a tennis ball. Then drive around. You'll notice no decrease in performance. Why? 90% of the air is coming in through that gap in the housing.
#6. The "foam" filter Weapon-R uses sucks rocks at filtration. Remove the filter and look inside your maf. Notice all the dirt?
Dump the weapon-r and go with something decent. If you go with a foam filter, go with HKS only. And for $80, the HKS filter is just not worth it.
Which intake specifcally are you interested in making? Can you re-post the photo or tell us who posted the original photo in this thread?
Random is offline
Old 11-21-2011, 10:23 PM
  #37
bigfishmoney's Avatar
thread is very misleading.. no pictures..
bigfishmoney is offline
Old 11-21-2011, 10:36 PM
  #38
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Thread is 10 years old man! If you want a Cold air intake get a Ebay one, then route it to the fender behind fog light, then find a instert to remove the foglight but finish off the hole!
Turboron_99 is offline
Old 11-22-2011, 08:30 AM
  #39
Blue Bomber's Avatar
Vehicle: 2004 Tuscani Tiburon
Lol I found this hilarious because bigfishmoney's mood is Amused because he revived a 10 year old thread, and Turboron_99's mood is murderous because he did that.
Blue Bomber is offline
Old 11-22-2011, 09:41 PM
  #40
This thread is . . .
Stocker is offline
