My project engine questions?
Ok, I'm buying a 2.0L Beta engine with all the trimmings (minus pumps, ac & gen.) and only 7k clocked.
First, my uncle works at a machine shop so the IM & TB are going for boring.
Second, I just got my 4-2-1 headers in last week and they are going to the ceramic coater with the IM and CAI.
Third, Planning on new valve springs and cam gears.
Fourth, an S-AFC is then nessecary to make her run right.
OK with all that said what am I missing? Keep in mind I don't want to go with larger pistons, turbo or SC, possibly NOS later.
Is more fuel required at this point, for example larger injectors, fuel rail, pump, regulator? or can stock handle it?
What else? any thoughts? Random any pointers would be greatly appreciated!
[ October 30, 2002, 10:18 AM: Message edited by: QUIKTIB ]
I got very lucky, there is a powder/ceramic coating company 5 miles from my house, and they are doing it pretty cheap, in my mind at least, 200 for the header and IM.
Porting a head should be something simple for a machine shop, right?
What are the pros/cons to a ported head?
head porting needs to be done by some one experienced in it. your opening the holes a bit to allow better air flow but at the same time you need to beware that too much and your cutting into cooling/oil veins etc.
Ropeman1000:
My ported head should be arriving some time next week.
Ropeman1000, did you send off your head or did you buy one already ported? Either way where and how much did it cost?My ported head should be arriving some time next week.
I still need some answers on my fuel questions (read original post). Random, Red, Brendan, anyone please.
Also, am I correct in the mods I need to have done or am I forgeting something?
Cam gears? There's no way to run cam gears on our motor. We only have ONE cam GEAR.(note the use of singular). You would be advancing and retarding the intake and exhaust cam together. Also, the only way to use cam gears properly is to dyno tune them. SO unless you planned on spending $200+ in dyno time to tune the cams...they are a rice accessory. (90% of cam gears are either set at 0 degrees or set at what "their buddy" said works best)QUOTE
An S-AFC is then nessecary to make her run right.
Unless you go with widly aggressive cams, it should not be NEEDED, but reccomended. Our cars run rather rich from the factory, using the S-AFC to lean them out actually will produce more power. Again, to be done right, it needs to be done on a dyno. Expect about $125 an hour for dyno tuning time, and plan on 2 hours. They might be done sooner, but plan on 2 hours.QUOTE
The stock fuel system should handle this just fine.the ported head would be reccomended. Hyundai's heads really suck for N/A airflow and can use some help!
Random:
Sorry, I was typing faster then I was thinking. I meant "cams", like the GT cam for instance. QUOTE
[b]
Unless you go with widly aggressive cams, it should not be NEEDED, but reccomended. Our cars run rather rich from the factory, using the S-AFC to lean them out actually will produce more power. Again, to be done right, it needs to be done on a dyno. Expect about $125 an hour for dyno tuning time, and plan on 2 hours. They might be done sooner, but plan on 2 hours.[b]
Thanks, I wasn't for sure it could. smile.gif [b]
Done. Minus S-AFC and fuel upgrade. Add ported head! Thanks to everyone, you've helped me out alot.
Peace.
Sorry, just to clarifiy a point.
The SAFC is not "needed" but it is "reccomended"
With similar N/A mods to what you have planned, Red was able to obtain an extra 8 WHP by dyno tuning the S-AFC.
Your car will run without the SAFC, but you will make more power WITH the SAFC.
[ October 31, 2002, 11:00 AM: Message edited by: Random ]
