My Custom Intake Photos
Well I am pleased to be able to share these pictures with you. I made this intake myself and it works great! After locating the battery to the rear, I had much space in the front. A friend with a metal shop helped out with a custom heat shield. I bought silicone boots from the speed shop, with the 2x 90 degree bend 3" aluminum pipe. It works and sounds amazing. Now for the exhaust manifold!!
Check this link for the pix.
Click for Pix.
Click for Pix.
Before trying this setup, I simply had a Apexi cone filter at the end of the Air sensor, with all the OG air intake setup removed. This way sounds and runs way better. When I first stepped on it after the install. I was so suprised. I should do a dyno soon. It sounds mean. Like serious. Loud! And I have room for an even bigger filter now. This work went very well.
