Motor Mount Bolt Size Help
Long story short i ran over a big rock in the center of my lane driving down the highway two days ago and now my engine cradle is bent. Bent engine cradle But upon further inspection i noticed that on the rear motor mount the two bolts connecting the mount bracket to the block are missing. Does anyone know what size those two bolts are or a schematic where i can find out. Also do you think i could call hyundai to get a part number or size, because ive already been to O'reilly auto parts with no luck.
Vehicle: 01 Tiburon
yes, the best way is to call your local dealership and find out the bolt size, thread, pitch and part # info directly from them.
to start, it's a metric thread!!!
I called Hyundai earlier and they couldnt give me the specs on the bolt or anything....all i got from them was a part number that no auto parts store in town seems to know anything about. The part number that i got is 11236-10456k, im pretty sure its going to be a 17mm bolt but im not sure if the motor mounts run a higher grade or not.
