MAF to MAP????????
Old 01-02-2003, 11:57 AM
EL Tiburon's Avatar
Default MAF to MAP????????
I've been hearing a lot of talk about switching from MAf to MAP. Is there any logic to this? What would be the pros and cons of switching to MAP on a NA set up? Would you recomend it?
Old 01-02-2003, 11:59 AM
Viper966's Avatar
MAF cars respond better 2 mods than Factory NA MAP cars which dont like boost
Old 01-02-2003, 12:15 PM
turbulence's Avatar
map is better for turbo tuning. if you're gonna stay n/a, don't worry about it. if you plan on going turbo, you'll need a map sensor WAY down the road. i don't know what airflow our maf max's out at, but it's fine for a lot of boost; more than you'll be able to throw at it for a while and with $$$. the map kinda makes a guess at how much air is in the manifold by the pressure, where as the maf actually measures the airflow, that's why the map is better for turbo. oh, and if you're going with a map sensor, you need a haltech or other standalone ecu. by looking at the install pics from red's car at www.hyundaiproject.com,, it doesn't look fun.
[ January 02, 2003, 07:18 PM: Message edited by: turbulence ]
Old 01-02-2003, 02:54 PM
Mav
Mav's Avatar
From what I've read on here, the MAF sensor is good to about 250whp. Red, anyone, correct me if I heard wrong.
Old 01-02-2003, 11:03 PM
In short, You can make either one work on the other system, in fact, most newer cars are MAP in N/A form.
There is no point to switching from MAF to MAP unless you are going to go to Forced Induction and a complete engine stand alone setup.
Old 01-03-2003, 01:35 AM
EL Tiburon's Avatar
Thanks for the info guys, but just to further my knowledge, does any one know where I can get the infomation required to achieve this swap, Since my buddy and I might be interested in swaping his over to Map.
Old 01-03-2003, 01:53 AM
Hyundai4g63T's Avatar
Vehicle: Had 96 Elantra Wagon
El,
Is he doing this so to go FI?
Old 01-03-2003, 02:25 AM
Bat Lord's Avatar
Vehicle: Ex Hyundai Owner
I believe he already is FI
Old 01-03-2003, 02:34 AM
The only way to switch from MAF to MAP for Forced Induction is do use a stand alone engine management system.
Haltec, Motec, PacTel, SDS, etc..etc..etc..
There's no point in trying to convert to a Stock MAP system.
Old 01-03-2003, 02:44 AM
Bat Lord's Avatar
told you so, your bud can't do crap until he has the money to purchase the HALTECH or MOTEC system, told you so tongue.gif ...
