Limp Stick
Vehicle: 1997 Hyundai Tiburon FX
Installed a RSide Advanced Short Shifter like 5 months ago right before the car into a 3way wreak(Front, Back, Passenger side). Was driving the car for the first time since then afew days ago and I noticed that even while in gear the shifter still wobbles side to side as if it were in neutral! Theres no firmness to it at all. tongue.gif
Whats the deal?
Whats the deal?
Try putting your stock back in and see if you still have the same problem... if you do... then its something from the accident and there could be something loose in your cables or trans
Even the OEM shifter has the same wobble in neutral. It's just a poorly designed shifting assy, not to mention it's all plastic down there.
Check out my DIY and make sure everything is in the right place and that your plastic spacers are not worn.
