Larger MAFS?
Larger MAFS?
Just wanted to know if it is possible to put a bigger MAFS into a Tiburon. Looking at the CAI
and all it makes me wonder how much power I could be getting if the MAFS was 3 inch
diameter inside.
Random or Red do you have any ideas on this? Never heard of it being done but is it possible?
Maybe the MAFS on the 2.7 Delta is larger to allow better flow to the bigger motor? Could it be
used on the I4 Beta?
diameter inside.
It can be done the only problem would be finding someone to recalibrate the MAF meter for the larger diameter. I had this done for my Stang when I went to larger mass air flow, but I'm not sure if the Hyundai meter can be recalibrated in the same way. Maybe I'll look into it, it would actually help out performance allot.
The problem is getting a larger MAF that is properly calibrated for the Beta ECU. Someone tried a Tibby MAF on an accent and ran RICH all the time. So it's not quite that easy...
In theory, you might be able to go with a larger MAF and an S-AFC to lean things out.
Guest
Posts: n/a
It is possible, but you would need to set back the swiper inside the MAF sensor. We do this for the Group N racing cars.
It is a long and tedious process and will require alot of patience and a volt meter. You will also need to measure the voltage at FOP (flap open position) and make sure that this voltage is not exceeded to maintain a decent CO level.
Also depending on the engine size, the flap has a tension adjustment aswell. too loose and you will surge when going round corners, and run rich when pulling a straight line....
Very tricky and not always successful.
The best solution would be to remove the MAF and install a MAP sensor and a programmable engine management system. the MAF's are way too restrictive!
[ March 20, 2002, 11:07 AM: Message edited by: UFB ]
Thanks for the responses guys.
Sounds like there is way to much work involved and too much tedious voltage testing and stuff. If someone comes across a workable way or parts please let me know as I am interested.
Thanks again.
Thanks again.
FordFasteR:
if we could get a maf sensor calibrated in a larger diameter, then the restriction would be gone, and you have more precise a/f ratios for the ecu than the dinosauric map sensor desiged DECADES ago.
The key word in that sentence was "IF". And that only applies to N/A Motors.if we could get a maf sensor calibrated in a larger diameter, then the restriction would be gone, and you have more precise a/f ratios for the ecu than the dinosauric map sensor desiged DECADES ago.
MAP's are much easier to tune for forced induction. Most MAF's do NOT like Pressure, and will fail if placed on the pressurized side of a forced Induction engine.
MAFs also cannot compensate for pressure, so they do not know the difference between 10 CFM air flow at 10 PSI and 10 CFM air flow at 0psi, and there is a LARGE fueling requirement difference between the two. For forced induction engines, MAP's are the way to go.
