knock sensor placement (strut bar install)
Old 06-01-2002, 08:08 AM
twistedH's Avatar
Default knock sensor placement (strut bar install)
I had to relocate the knock sensor to install my front strut bar (a topic which I know has been covered) but here's my question: I kept the front of the sensor pointing the same direction, but had to rotate it 90 degrees. Will that rotation have any negative effect? Here's a pic:
Thanks,
Old 06-01-2002, 11:05 AM
You want it pointing forward back, no exceptions. 90 degrees will affect it.
Old 06-01-2002, 01:11 PM
twistedH's Avatar
Right, right, the front of the unit is still pointing in the same direction that it originally was, but essentially "rolled" 90 degrees like so:
Will that kind of placement affect its operation?
Old 06-02-2002, 01:54 AM
Decker's Avatar
what kind of problems? well if you rotate it 90degree's your car won't know when you've hit something head-on or from the rear. Sooooo you airbags won't deploy. And depending on your beleifs on airbags, bag things could happen. Its usually a bad-idea to mod anything that pertains to the passenger safety.
I went with the SR strut desgin. This allows you to keep the shock sensor in the same position with little bending.
Old 06-02-2002, 04:43 AM
twistedH's Avatar
I don't know how to say this any other way. The unit is pointing in the *exact* same direction as it was before I moved it. If I'm standing up and facing north, and I then lay down on my side, I'm still facing the same direction, right? Please, will somebody understand what I'm asking here? The sensor is facing the same direction it was, only now it's "on its side," if you will.
Old 06-02-2002, 04:59 AM
pare_john's Avatar
The knock sensor is there not for airbag purposes. It is there so the ecu will not think that there is a knock in the engine when going over bumps.
It is also just a knock sensor aid. The real knock sensor is on the block. This sensor like i said is there so the car will not mistake a bump in the road as a knock in the engine.
Old 06-02-2002, 05:22 AM
erikgsi's Avatar
i dont know about on the tib but on the accent you can put it back in the same place it was but on top of the strut bar mounts.
Old 06-02-2002, 08:05 AM
W??? p_j where did you hear that? It's the shock sensor for airbags!
the knock sensor is in the block! if an engine knock sensor were anywhere BUT the block it would be worthless.
Old 06-02-2002, 11:14 AM
twistedH's Avatar
*sigh*
Old 06-02-2002, 03:42 PM
twistedH:
90 degrees on it's side is NOT the exact same way it was pointing. It needs to be Mounted the EXACT SAME WAY 90 degree's, 180 degree's makes a difference. Mount it exactly the same as it was. do NOT rubber mount it. It must be mounted directly to the frame.
