Injector / Fuel pressure reg. Question
Hello, So I have all this good stuff off now. Intake manifold, rail, injectors and I had a couple of questions. (99 Tiburon)
1. Can an aftermarket fuel pressure regulator be used on the stock rail?
2. How can I clean the old injectors? And, with what injectors should I replace the stock ones with. I am going to soon add a turbo.
3. After I replace the injectors to bigger size ones, will I NEED a different fuel computer right away, or will the stock ECU figure it out and give less fuel, till I get my hands on a SAFC?
If I get any help with these questions, much appreciated. I am doing all the work myself and on another note I also got the MSD DIS II figured out.
it depends on what size injectors you replace the stockers with as to if you need a new/piggyback ecu. i've read of some people using 10% larger injectors with stock ecus. if you're gonna get 440cc injectors, then you need a new/piggyback ecu.
Since you want answers for a turbo setup, moving to Forced Induction forum.
2Uniq- You've got a warning in your email box. NO PERSONAL MESSAGES HIJACKING THREADS. off_topi
[ April 06, 2003, 09:34 PM: Message edited by: Random ]
