Increasing my torque a bit?
I have a 2002 Daewoo Lanos with the 1.5SOHC engine. Its quite gutless as you can imagine. Whats the best way to get a bit of power from the line?
I was guessing a 4-2-1 headers, 2" exhaust and a custom intake? is there anything im missing? or am on the total opposite track?
D4Damager:
I think the guys from Jamaica will pipe up here... afaik this is the engine they get, and over in europe.I have a 2002 Daewoo Lanos with the 1.5SOHC engine. Its quite gutless as you can imagine. Whats the best way to get a bit of power from the line?
American market Lanos' were equipped with 1.6 DOHC engines.
For low end torque, a campy trick in the SOHC dodge camps was to change the cam timing with an offset key... you could shift the peaks up and down a few hundred RPM by that alone.
Red:
Type-H, I don't think a 1.5L is going to produce torque in equal quantities to yours. Let's not get someone excited here...
Never compare the quantities.. compare the percentages smile.gif Type-H, I don't think a 1.5L is going to produce torque in equal quantities to yours. Let's not get someone excited here...
190 to 210 is a little over 10%... on a 120Lb/ft engine, that'd be 132lb/ft.
Mike;
Mine is a 1.5 I am sure of it. In my owners manual it shows the 1.5 and the 1.6 DOHC, and the difference is clear, i have the 1.5. I live in Canada if that makes a diff?
So what was this other trick you mentioned? any links to that?
The problem is that you're dealing with two totally seperate engines. Headwork doesn't put another 10% gain on every car...
A back-to-back dyno test of a BETA with and without headwork, my motor gained about 2 wheel horsepower. That's headwork in combination with intake, throttlebody, intake manifold, intake cam, HVE header, full exhaust, one of the only chipped Tiburon ECU's in the country and an S-AFC.
Two horsepower. Let me tell you how excited I was that I spent $450 on two horsepower... rolleyes.gif
There is no general rule for engine work gains. I am stressing to Type-H and anyone else listening that you should never use your OWN gains to promote work to someone else's car unless you're dealing with the same platform.
If Type-H was suggesting headwork to another 2.5L 4-cylinder owner, then he would be making a good recommendation. But his experience with the 2.5L isn't going to cross over to the 1.5L -- for better OR worse.
