High Idle
Old 07-13-2004, 09:24 PM
koykoy's Avatar
if the engine is deprived of air, it will go into higher idle...
you can also check your intakes
Old 07-14-2004, 03:47 PM
Hobgoblin's Avatar
Vehicle: 2015 Subaru WRX
Default test
whats a TPS...
Old 07-14-2004, 03:59 PM
wattsup4800's Avatar
Throttle Position Sensor
its connected to the TB
i believe it lets the computer know how open or closed the TB is
Old 07-14-2004, 05:32 PM
TiburonWao's Avatar
Thanks Hobgoblin... I will ask about the meaning of TPS... Something new that I learn today..
I also think that you should check the TPS.... as everyone saids... and in the way, check the fluids....
At in the worst cases, maybe the clutch disk don't get separate from the Flywheel.... so it keeps REVS....
Just check... it's not normal...
Old 07-14-2004, 05:41 PM
Hobgoblin's Avatar
Thanks for all the assistance guys!
Old 07-15-2004, 07:43 PM
Loneshark's Avatar
Vehicle: 2000 Tiburon
also take the idle speed controller off the intake manifold, and clean it with brake cleaner, and let it dry out for an hour, sometimes it gets dirty.
