Hi fellowsharks
Hi fellowsharks
Hi guys i am Kostas and i drive a stock 2.0ltrs tib.I was surfing in sharkracing´s site but i wasn´t able to find a cai.It says there TBA...What´s going on?Also i´ve made a search but i can´t figure out where or which is a good cai for my car.I don´t have the knowledge and tools to make a custom one,so i need sth good and easy to install.
PS:Is the cai of sr still under construction?
And if so when will it be available for us??
Waiting for your answer.
The SR CAI is through the first prototype, and should have the second prototype done in about 2 weeks. If the second prototype is perfect, it will then start production.
However, if the 2nd prototype is NOT perfect, and still needs alteration, it will take another month or so for a third unit to be built.
Chances are, since you have a European Tiburon, that uses a different air sensor configuration, it would not work on your car. It would have to be adapted for your car. Shark Racing is considering making a CAI for the European Beta motor, but I do not know how far along it is.
In the meantime....
You CAN make your own. Here are the details on
How to make your own Random Special CAI
[ February 23, 2002: Message edited by: Random ]
In the meantime....
Thank you very much Mr Random..
I have 3 questions if you wouldnt mind answering me..
1)Can i put a Simota TopGun Airfilter instead of a cone filter at the end of cai??(I am afraid of dirt and hydrolocking my engine).
2)If i take out the stock airtube from the tb till the airbox,can i put the flexible tube from the tb to the airfilter??(My motor doesn´t have a knocksensor,it only has the IAT sensor and two other small hoses near the tb for the fuel i think)
3)This rubber elbow from the tb i think is not stock.How can i make the holes at the elbow so that i wont have any gas leaking from it?
Thanks for your time and understanding reading my post.
Kostas.
Kostas.
