Help With Injector Install Diy
I have some rc engineering 440cc that I am going to install before the Alpine goes in.
Not to sure if there is anyting I need to do other than throwin em in there?
Please help with some instructions
Pull the fuse for the fuel pump and crank the engine till it won't start anymore.
Then pull the fuel rail/injectors. Remove the old injectors, and install the new ones.
Re-install fuel rail/injectors.
Put fuze back in.
Crank for about 15-20 seconds and the car should start/fire.
Put fuze back in.
