Great flow no noise
Great flow no noise
I'm looking for a very high flow muffler that is pretty quite. I realize that if a muffler is very quite it's probably very restrictive but I figured I'd ask.
I don't want a loud car but do what the performance boost.
Pick any straight through designed muffler you want.... But I warn you some performance mufflers are DESIGNED to be loud (OBX, RACTIVE)... My straight pipe setup is quieter then JAWS 01 and Neo_Tibs AND KaiJai's OBX setups. I have straight pipe w/no muffler but I installed 2 1/4 piping with a 24" thrustmaster glasspack ($32.99 canadian). Its a catback and its very quiet, and vey highflow. You would not believe how much noise the glasspack gets rid of WHEN ITS INSTALLED BEHIND THE CAT. If you install it at the tailpipe, it will be very loud...
-Steve
-Steve
What would be the quietest performance muffler in your opinion?
I want to combine a 2.25" inch exhaust from the flex pipe (We don't have cats, so this flex pipe is right below the engine) to the rear. I'll use two 18 glasspacks.
The point is, I want a good flow, but I can't have a too loud exhaust, so I would go for the quitest.
How good is the FlowMaster 60 series? It's supossed to be "quiet" and it's designed for imports, isn't it?
Thanks
Thanks
