Got A Problem
i will check here for you,
to change that you got to drop the bottom half of the exhaust mainfold "if you are running a stock one"if not the whole thing must come out.
the crossmember
short form you got to drop the oil pan and the timming belt
its not that hard i did it in 4 hours, + 2 soju
but that is way to much, how much is the pump AKA frount case assambile in the US
*note to all brother here a OEM oil filter here is 5 bucks if you need some let me know.
the crossmember
