getting out the hex plug for the oil feed
Random,
did we ever come up with a consensus on how to get that stupid hex plug out for the oil pressure feed?
I about stripped it with my hex wrench, and I have a set of screw extractors I can try.
I found several threads discussing it, but we never seemed to reach a conclusion. Reverse threaded?
I'm installing my gauges this weekend and was just curious.
thanks in advance,
ac
thanks in advance,
ac
Here's a trick for Allen pipe plugs...
give it a couple of hammer blow to loosen the treds a bit then put the Allen key in it (hammer the key a bit into the plug) and apply force at a straight angle on the ratchet ( no angles or you will "round" the allen hole
if the hole is already rounded of a bit you could hammer it a bit then hammer in a non-metric allen key in it
if that fails use a "round" shaped extactor
on my car i installed my oil pressure gauge in the same spot used by Hyundai for the oil pressure switch ,i just used a STELL T fitting
Denis
Denis
Thanks. I also found out that the hex screw in the top-center-front (how's that for confusing smile.gif ) is also in the same oil galley as that hex plug on the end. That's probably a lot easier to get out. My problem is, I only have a 1/8 BSP to 1/8 NPT adapter, and I believe that plug is a 10 mm x 1.25. Oh well, time for another trip to pep boys.
If I can avoid it, I'll tap the oil elsewhere and avoid that hex plug altogether. Too many horror stories (including one that involved drilling and having to flush the head to get the iron filings out, b/c they damaged the valve area. DOH!).
thanks,
ac
thanks,
ac
