Fuel pump rewire
Vehicle: 2006 Elantra
Fuel pump rewire
Has anyone ever done a rewire for the fuel pump? Or has anyone had an issue where the fuel pump was not receiving enough volts? And what is normal voltage for the fuel pump?
Vehicle: 2004 Hyundai Accent
see www.hmaservice.com to confirm, but should be straight 12V off a battery. on/off controlled by the fuel pump relay.
make sure you know where the fault is before you start rewiring.
