Fuel Pump....
You would only need a better pump if you need more fuel. I think you need more fuel around the 180hp level. Check Brendan's site. The calculations that were used to derive that number are on there. Truly you would only need more fuel if you are using NOS or some form of forced induction. Are cars usually run rich from the factory so there is plenty of room mods without a better fuel pump. On the other the hand it is pretty cheap insurance. It will not hurt any thing buy installing it.
