forget msd module kits
Vehicle: 1997 Hyundai Tiburon FX - now 2006 Infiniti M35 Sport
I apologize if this has been covered before, but I was doing a little search and ran across this.
If you have an msd rpm window switch, you need to purchase 2 sets of module kits. One for the turn on and one for the off rpm's. That runs around an extra $50. Worst of all, those are set rpm values. I ran across this and thought I would share. You can make your own variable selector for both the on and off rpm's for even lower than the cost of the two kits. I know this is valuable for those who are running nitrous and want to find the optimal rpm window to work with. Follow the link below to find the instructions.
http://www.corral.net/tech/powerplant/arm/
