FordFasteR 1/4 mile times are HERE.!
#21
another horsepower calculator shows ...
Horsepower Results - 1/4 Mile Method
Your Hyundai weighs about 2850 pounds and can complete a 1/4 mile in about 15.298 seconds. That means that you've got about 157.34 HP at the wheels, and about 204.54 HP at the flywheel.
this calculator shows that i lost 47.2 HP through the drivetrain and wheels... thats about 23% of engine horsepower ...
strange.
[ February 16, 2002: Message edited by: FordFasteR ]
strange.
#23
heheheh ok.
i'm not at home, so i cant put it on my web server from here...
how can i make it show here ?
i will scan it and post it tomorrow using a link to my webserver...
#24
When i had my auto tib i was running a CAI,4-2-1 headers with full 2.25 inch exhaust,S-AFC,Bored TB 58mm also Port matched Intake manifold and cylinder head work as well as valve job.I ran a 55 shot of NOS and i ran 156-158 Wheel HP.
There is no way with just a 55 shot of NOS and with no other mods you have as much HP as me at the wheels.Something is not right here????
#25
once again, noone is doubting his times, so by showing us his timeslips that will only prove that he's telling the truth about the times, which I BELIEVE cause of that NOS, but his dyno readings are way off... sorry
Don't ever post dyno times man, until you've got a dyno sheet to back it up, calculations done by a program won't back it up or work here, trust me man... smile.gif
#26
I agree with you BAT!!!
Im NOT DOUBTING HIS TIME SLIPS in terns of quarter mile time but his SO CLAIMED 158WHP is way OFF.I basically have all the N/A Bolt on mods done to my car and i pulled a 158WHP and my 1/4 mile time was 15.2 ON THE DYNO,never had a chance at the track.
I would doubt if his times were done on the DYNO?
#27
Hey I'm with Bat and 2uniq, and I have the dyno to prove it, my auto
stock dynoed 98 hp ( non adjusted dyno ) @wheels, after some mods 113
hp ( no exhaust ) then 123 hp with exhaust and headders ( working o2
sensors and reset ecu ) and with a 55 shot 149 hp @ wheels ( that was
before the exhuast tho ). That and the windows calculator isn't that
accurate. Remember Chris H was dynoing 150 ish hp @ wheels and ran
14.6 on a 5 speed. lets just say dyno before claiming numbers, but a
15.2 isn't bad, 14.9 is what the auto does with the zex on a 65 soht
under ideal conditions.
#28
That's a good time for a slushbox.
I'm not a fan of 1/4 mile to hp calculators... they are all just guestimates and some of them are not even based on real mathematical formulas... just a formula that seems to fit. TRUE and TRUE but unrelated. Also most of the formulas were built around high torque V8's numbers.
Automatics 2.0L Betas push around 105-110 hp at the wheels so a 70 hp nitrous shot should do the trick.
Also we shouldn't confuse 70 wheel hp shot vs a 70 engine hp shot. I believe most companies rate engine hp increase.... but I know that NX nitrous systems rate their shots at the wheels. Which hp is your system rated at?
I think that with a little practice more than a little more bottle pressure.. you should be in the 14's.
Just take the car down to the dyno and spend the $50-$100 and have them run it with the nitrous and an a/f curve. Then you know for sure that you are spot on with the fuel... and you get to know exactly how much power you are making on and off the bottle.
I don't know why people are so hesitant to go to a dyno. It's great fun... exciting watching the curve plot and you can meet some really cool people and you get a no bullsh*t answer.
#29
i've been to the dyno with all of the cars i've ever owned (but not yet with this one)... the time will come soon... i just would rather spend the dyno money on headers.
what headers will make the most torque ?
4-2-1? or 4-1 ?
regards.
4-2-1? or 4-1 ?
regards.
