Flex-a-lite Fans
Old 07-20-2005 | 08:53 AM
  #21
Actually, that's not right. The engine bay will be cooler, and your precious parts won't have as much heat degredation because of it. The engine may also be a bit cooler too because it's not sitting in a oven. Cooling of the engine can EASILY be helped without messing with the radiator system.
Old 07-20-2005 | 09:25 AM
  #22
JonGTR's Avatar
Ok, all I'm gonna say is, if you want ACTUAL and NOTICEABLE performance from them:
1. Get a lower temp t-stat.
or
2. Put the fans on a manual overide switch.
Done here.
Old 07-20-2005 | 09:38 AM
  #23
I am a firm believe in the manual over ride switch. This might come from my background in Italian cars. The Fiat 124 was one of the first cars to use an electric fan... it's wiring and switching tend to be a little fragile, so we usually wire in an override somewhere just to be safe.
Old 07-20-2005 | 09:47 AM
  #24
BIGTRE13's Avatar
QUOTE (JonGTR @ Jul 20 2005, 08:03 AM)
I'm in 100 degree weather most of the summer, and the fan is never constantly on. There's just no need for them, especially for anyone living north of me.
$200 will buy a lot of other MORE useful parts. Something that you'll enjoy everyday and not hidden under the hood providing no power gain.
Jon you are correct, however, when I install the turbo I will need all the extra little space that I can save.
Just letting everyone know that I have received my fans. I am feeling a little sick I may just have to *cough *cough* leave work *cough* early
Old 07-20-2005 | 05:20 PM
  #25
QUOTE (JonGTR @ Jul 20 2005, 09:25 AM)
or
Done here.
1. Done
2. Done.
Heh heh...
QUOTE (BIGTRE13 @ Jul 20 2005, 09:47 AM)
Same for me with my GT HEaders, not to mention, I'm going Turbo next year.
ROTFLMAO!
DO A WRITEUP, get 1000 RD points.
Old 07-20-2005 | 05:31 PM
  #26
BIGTRE13's Avatar
unfortunately it is 13 hours after I got to work this morning and 7 hours after my fans arrived at my job and I am still here *working* because of a stupid *glitch in the matrix* mad.gif mad.gif mad.gif
Old 07-20-2005 | 05:54 PM
  #27
Mad_john's Avatar
ok guys, i got the felx-a-lite 220 and thaey dont fit 100% the only way that they wouold fit is if i remove the rubber molding arould the shroud, i looked at all the posts here and you guys said to get them so i did.
pros,
space losts of it
looks
2500cfm
A/C is cooler "colder" it seems
running temps are cooler
cons
did not fit perfert it sits at an angle like this /
some noise
some asamble requrted
or maybe i got the wrong one
School me brother
Old 07-20-2005 | 06:36 PM
  #28
I've been told by several folks it's a perfect fit.
Like "It's like it's made for our car" perfect fit.
Old 07-20-2005 | 07:28 PM
  #29
Mad_john's Avatar
mmm maybe i put on wrong.
what is the whireing for and switch to contronl them mannual so both fans kick on and off
now that would be tight
Old 07-21-2005 | 01:17 AM
  #30
'treezy's Avatar
has anyone done a write-up on how to wire a on/off switch? I would like to buy one of these mainly for the performance aspect but have no clue where to buy a lower thermostat and like having the power over my FAL's...
