Final Drive
i have a 2001 tib with the 5 speed i was wondering i need a new final drive gear for my car its way to slow on the freeway, in fith arround four grand im going 80, is there anyway to get a 'taller' fith gear or a better final drive for top speed, the lag doesnt bother me as much ,the turbo helps acelleration i just need more to play with
thanks
thanks
i got a 3.056 in mine extra long for the turbo now, but the one i had before for 4.294
the ring gear and the input shaft is about 100 buck here from hyundai servicee here but if you want longer 5th then go with the 3.056
55mph=2500 rpm
65mph=3000 rpm
hope this helps
55mph=2500 rpm
65mph=3000 rpm
hope this helps
How does lengthening 5th affect performance? I am interested in doing this, it would save on gas too. As hamhead always says .. the term highway miles isn't really appropriate on the tib because of it's aggressive gearing and very short 5th, 70mph is over 3k on the tach.
it will only affect top speed positively, and acceleration negatively. you're not really trying to accelerate fast in 5th gear though anyway.
as supry said, the elantra tranny is a great idea for anyone wanting a bit better fuel economy. i know 5th gear is taller, and i believe 4th may be by just a smidgen too.
fing02.gif Hamhead quote, very nice.
Having a longer 5th for gas mileage really isn't a bad idea. It will probably pay for itself over time. Of course, with N\A, your probably going to have to downshift to 4th to get any passing performance out of the car.
Mad's 3.056 sounds just about perfect, since you don't wanna go too long on the gear and put more stress on the tranny itself.
so where do i get the gears from kspec? do you have part numbers?prices?how much would it be to install cause i might just get a lsd while im at it.. thanks guys, but i dont want to go the elantra route, i still like acceleration to fourth but i need more top end on the freeway, cause of the turbo im running out of room to play with
you said 3.05 gears right?
3.056 is FGR and its a 100 buck here if you need let me know
john
or send me the tranny and i will get it done here ok. PM me for details
john
it's funny.. this is one of those areas where I am spoiled. My last couple of cars have all had pretty aggressive gearing. In comparision, the tib is a highway cruiser.
My old excel topped out at 95mph with a tail wind and going downhill. It was SCREAMING at that speed too.
My fiat has a 4.40 rear.. 70MPH is done at just over 4000 on the tach in fifth...
But I will admit, it would be nice to be able to cruise along effortlessly at 70mph and only pull a lazy 2500 on the tach.. unfortunatly, unless you were boosted you would have to downshift for anything more than the slightest hill.
