FGR question
4-1 Header Gasket
QUOTE (tibwrcsbj)
There is a 10 line limit for signitures here, please reduce yours to that limit......
I'm gonna PM him if he doesn't see it in the next hour.
Ahhh, I looked it up for you.
QUOTE (Originally posted by turbulence @ HyundaiAftermarket.com
umm, from what www.hmaservice.com/webtech says, our final gear ratio is 3.650 (for both 1.8L and 2.0L).
Re: 4-1 Header Gasket
just in case you need other tranny ratios,
http://www.hmaservice.com/webtech/iindex.a...0783#_394880783
Re: DIY - Resetting your ECU
yes, higher the ratio, shorter the gears.
i think this fgr is more suited to drag racing. you might wanna look into something like this though...
http://www.rdtiburon.com/old/index.php?nam...iewtopic&t=1193
