View Poll Results: CAM Pully, Worth it or Not?
Worth the $100
37.50%
Not worth the $100
62.50%
Voters: 8. You may not vote on this poll
Exhaust Cam Pulley
Old 06-22-2005 | 08:31 AM
UltraTibby's Avatar
I am going to be changing my Timing belt in the next few weeks. Already bought the belt, idler, and tensioner. I am considering buying and installing an adjustible/lighter CAM pulley. My question is, is it worth the $100 and what kind of HP would they allow?
Old 06-22-2005 | 09:38 AM
brian01tib's Avatar
http://www.nitrousworld.com/cam_sprocket.php
Old 06-22-2005 | 09:50 AM
UltraTibby's Avatar
So I guess from reading that article that it isnt the actual weight of the pulley that makes the power difference it is the tuning on a dyno of the sprocket that actually did it?
Old 06-22-2005 | 09:56 AM
JonGTR's Avatar
Get the crank pulley instead. Gives more hp/tq and is cheaper. $63 + $13 ship on ebay.
Old 06-22-2005 | 10:00 AM
brian01tib's Avatar
he can do both
Old 06-22-2005 | 10:02 AM
UltraTibby's Avatar
QUOTE (JonGTR @ Jun 22 2005, 11:56 AM)
Old 06-22-2005 | 10:15 AM
Well according to that dyno he got 2 hp and 3 ft/lbs of torque is that really worth a hundred?
EDIT
a hundred plus dyno costs
Old 06-22-2005 | 10:42 AM
hamhead's Avatar
Don't forget dyno time to get them tuned... that'll almost double what you payed for the sprockets. BTW, I believe you need both the intake and cam sprocket pulleys for it to work... if I'm not mistaken. ;?
Old 06-22-2005 | 10:57 AM
UltraTibby's Avatar
Nope there is only one sprocket that attaches to the timing belt (the exhaust sprocket). Then on the other side of the exhaust cam there is a chain that attaches the two cams. Those sprockets look to be made into the cam while the one on the end of the exhaust cam is removable.
Old 06-22-2005 | 11:11 AM
Kspec has an adjustable sprocket to replace one of those chain sprockets inside the head.. no idea how though. Like you, It looke to me that they are a perminent part of the cam.
