Evap Question
I tested my car recently with an obd reader and it came back: evap emission control system vent control circuit 0446. I did some google searches and was just wondering if this is a solenoid problem?
And if so, where would the solenoid be located? And is it expensive to replace? Thanks.
do a search on THIS site for evap or P0446. There is EXTENSIVE discussions regarding the EVAP canister and what to do with it. You have a 1997 revolution A tiburon, this was the "first" design and the EVAP cannister is located under your battery, accessible if you remove the f. l. wheel and splash gaurd. Also removing the battery and batt. tray helps get to the fuel and air lines running to and from it.
G'luck!
G'luck!
i did a search on this site for more info on the code 0446, but didnt come up with much. my main question is : is the vent control circuit a solenoid problem? and could that affect performance?
You are crazy or search like a moron.
http://www.rdtiburon.com/index.php?act=Sea...;highlite=p0446
Click SEARCH, make sure "SEARCH THIS FORUM ONLY" is unchecked", and put in "p0446".
Hit enter.
There's like 5 threads on JUST that subject, a few are pages long.
Read.
Hit enter.
Read.
