Engine Knocking After Oil Change.
#25
QUOTE (Stocker @ Apr 28 2009, 08:34 AM)
^ to expand on that, I point out that Hyundai says don't operate the engine above 3kRPM with lifter noise.
Can I please get a reference on that?
#26
DTN it's on hyundaitechinfo somewhere, maybe in the troubleshooting for valvetrain noises. They said for HLAs that had been dried out by sitting, run the engine <3KRPM and it should clear up in <15 minutes or there might be another problem. I saw it when I was tired and I'm tired now so please excuse my not wanting to go digging for it right now.
#28
Well if you have done what everybody before recommended and the problem still persists then I'm going to guess you have a bad HLA (or more than 1).
You hear the noise coming from the top of the engine right?
#29
I really dont think the engine is knocking.
I think its the HLA's.
GFTIBURON is it like a ticking sound? It should increase with RPM's and you hear it better when it echoes off a wall/another car next to you.
Right?
When the car is cold it should tick and then stop if you let it idle in morning.
Then after driving for a while it will come back.
Then its not knock.
Its probably your HLA's
#30
Vehicle: 2001 Hyundai Tiburon SE
The noise is coming from the top of the engine. It sounds like a knock but goes away if I rev the engine a bit.
How much does it cost to fix the HLA's?
