Debating Sign Groves
Old 04-03-2009, 01:58 PM
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
Well Stocker got me thinking about doing some sign groves.
So far i have decked the head. and had it cleaned.
(picture of possible groves)
(closer look at possible groves)
(picture of top of head)
(picture of intake port)
(picture of exhaust port)
I have had the 1.8 pistons pressed on to the stock 2.0 rods.
(1.8 pistons and 2.0 rod)
sent out the block for honing and glazing.
(picture of cylinders)
sent out crank for polishing(wanted to get it lightened but its way to expensive)
(picture of block on hoist)
(p&P intake manifold)
also ordered new rod and main bearings
got some new head bolts
XD head gasket for raised compression as well
new timing belt and tensioners
I am going to clean up the engine bay really nice while i am at it as well as it stands right now it looks a mess.
(engine bay i know its an auto tranny but its rebuilt and only has 3000 miles on it so it will do till i get around to swapping it)
the crank pulley is chipped so i am in the process of ordering obx under drive pulley.
my current setup is
P&P intake manifold.
msd dis 2 62112
warm air intake
header
full exhaust no cats
75 shot of nitrous
O2 simulator to get rid of cat cell
Old 04-03-2009, 04:35 PM
Nice. I remember my bill for my machine work with knife-edging, lightening, and balancing crank. Never want to go through that cost again. Looks like you have a nice setup. Should be fun. fing02.gif
Old 04-03-2009, 04:46 PM
tib _500's Avatar
it looks like so much more in pictures than words. my old block was so clean cant believe i sold it, the more and more i think about it. cant wait till your car done. i can take a ride and you can help me with my 5 speed swap laugh.gif .
Old 04-03-2009, 05:18 PM
iheartmyrd's Avatar
Update on the sighn grooves
should i go deeper you think or does that look tasty enough
Old 04-03-2009, 05:27 PM
Im still not sure I buy into that whole thing or not. Im going to ask about it when I get my head machining done and see what they say.
Old 04-03-2009, 05:29 PM
iheartmyrd's Avatar
it obviously can't hurt any thing as long as you stay within the cylinder, so i figured i would give it a try.
Old 04-03-2009, 06:26 PM
I believe signh grooves are supposed to be more angular rather then rounded. The idea is to create turbulence.
Old 04-03-2009, 06:36 PM
iheartmyrd's Avatar
there are many different methods and both triangular and rounded both work the same. its documented
i re touched them a little and put the dremel away.
Motor should be put together and in the car next week end.
stocker i was hoping you would post in here since you swayed me into it = P
mentioned rather than swayed actually but w/e
Old 04-05-2009, 02:59 PM
I am actually really looking forward to your engine's running. I am hoping to use my 1.8L pistons also, along with maybe some milling off the bottom of the head. If you tell us that you can run on Regular instead of having to increase the octane rating of your gas, that will be an encouragement to me! I think member agreen said he had to run 89 instead of 87 after installing the 1.8L pistons. I anticipate that, with the grooves, you may not. We'll see!
Old 04-05-2009, 03:30 PM
iheartmyrd's Avatar
well stocker my block will be back on Tuesday and that's the only thing i am waiting on.
I am really excited!
