Clutch Install Problem...
#32
I only paid for original labor plus a stock clutch kit.... luckily that Stage 2 didn't cost much, but if I find a way to prove it was his error then believe me I WILL be going back there....
#34
interesting.. a little lube to get the splines onto the shaft I can see.. but I think that is FAR too much. Honestly, I never used lube when installing a clutch. I have to wonder if some got on the pressure plate or the disc and contaminated it.
Also, talk to the people you bought the original setup from. See if you can return it for a refund or to see if it is damaged by the mechanic. Be upfront about it to them, see what they say.. either way, you will be getting some money back from somebody.
#35
^^ Thats what it looks like to me anyway. They used too much lube trying to get it together, and that lube made contact with the disc surface and made it slip.
Either way, thats much lube was unnecessary.
