Clutch Change Question
When I go to put the ACT clutch on and flywheel and all that would it be a good idea to change the clutch release bearing?
Or is it not going to make that much of a difference? I am just figuring while it is off and all I might as well but if it is not neccessary then I am not going to mess with it.
basic rule of thumb is to buy the WHOLE clutch kit and not just a clutch.
and yes, you will want to replace the bearing.
i would also get a new pressure plate along with the bearing. theres no point in having an upgraded clutch and new flywheel, with an old pressure plate and old bearing.
I know the clutch info, with the pressure plate and all that I just did not list it I have an aftermarket pressure plate clutch and flywheel, just waiting for the car to get back so I can put it in I just did not know if the bearing was necessary to change. Any other things I should change out while I have the car up and the old clutch off?
Vehicle: 1999 Hyundai Elantra
Don't forget moly grease on the many bolts outside the bellhousing and on the input shaft in case you have to tear something apart again. The bolts come out a lot more easily then.
i use antiseize on EVERY bolt.. i love that stuff.. i used it on my transmission, suspension, lug nuts, etc. no more rust welding together. once you break a bolt loose, you can spin it out with your fingers. really nice to have.
i use mutlipurpose grease on the input shaft.
o, antiseize or anything like that is not recommended on parts like that.. or at least i wouldn't use it on that kinda stuff.
those are easy enough to get off anyway.. i don't use thread lock though.
