Cleaning Maf With Electronics Cleaner
Sure. Make sure the car has been cooled off for some time.
1. Remove MAF from intake stream by removing hose clamps.
2. Remove wiring harness from MAF by removing silver metal wire that holds it in place with a thin flat blade screwdriver.
3. Pull MAF from the car.
4. Spray inside of MAF thoroughly from both ends, making sure you hit the center of the sensor.
5. Let dry.
6. Reinstall.
5. Let dry.
6. Reinstall.
