CLeaning the engine Bay
Old 06-08-2002, 09:05 AM
SONiCBOOM's Avatar
Default CLeaning the engine Bay
Hope this fits this board, if not sorry smile.gif I just wanted to know how you went about cleaning the engine bay. What product do you guys recommend.
Old 06-08-2002, 09:18 AM
d_m_kolb's Avatar
I have found that spray on wheel cleaner full strenth works great. Make sure the engine is cool and spray everything. Let it sook for a few minutes and then spray it all off with with a garden hose.
Anything that didn't come clean use a cloth and spray wheel cleaner on it and wipe it down, then spray it off. I have done this for years and the wheel cleaner has never messed anything up. It works great.
Old 06-08-2002, 09:22 AM
blue_streak666's Avatar
Vehicle: 1999 Tiburon
well, at work to do this, we use a light duty foaming degreaser as an engine shampoo. YOu just spray that stuff all around, scrub the heavily soiled areas and rinse it all off. After that, i just use a light all purpose degreaser to finish up what ever is left behind, and then use the appropriate detail dressings to shine it all up for show. Hope this helps.
P.S. Sorry i don't have any product names for you, our work uses products from a small locally based company so there is no generic names.
Old 06-08-2002, 10:16 AM
9o7TiB7o9's Avatar
And if you have an aftermarket intake, thus an exposed filter? and mine is a Dragon Air filter, so it's foam-based, I'm pretty sure probably the least amount of water-resistance available smile.gif
Old 06-08-2002, 10:45 AM
Easy, just cover the intake filter with a garbage bag and tie tight.
Or...
Take the filter off, put some saran wrap around the tube, and rubberband it on.
Old 06-08-2002, 10:59 AM
SONiCBOOM's Avatar
k well my engine is completely stock so I don't have to worry about anything getting wet. Thanks for the info guys, I think that will be my project for tomorrow.
Old 06-08-2002, 02:21 PM
Kate's Avatar
We used some stuff that came in two seperate containers .. bought at the local part shop.. for the life of me..can't remember what its called but its specifically for engines.. Here is what mine looked like after it.. Keep in mind it had never been cleaned before (like 2+ years)
http://photos.yahoo.com/bc/crazykeep/vwp?....view=t&.hires=t
Old 06-08-2002, 03:03 PM
Koreandude's Avatar
I know what you're talking about Kate, but i think they stopped making that product, so i've heard....
Rich
Old 06-08-2002, 04:11 PM
KayJai's Avatar
No they still make it
CD2 Engine Cleaner
Good stuff,... stinks but works well
Old 06-08-2002, 04:34 PM
Hootie's Avatar
Simple Green. Spray it on concentrated. Scrub the hard spots and rinse off.
There's this foaming detail stuff you can use afterwards. Spray it on and let it sit. Then wipe off the excess. It will look like Liquid Wet in your engine bay.
