Champion Manifold???
sup guys, well does anyone know who to get one from, I emailed Cheuk like 2 other times inquiring on how to order, but I guess he's away and hasn't been able to get in touch.
Does anyone else know how to?
HRD, if ya would come on AIM, I would have told you, but since you dont do that anymore.
Cheuk does not have manifolds made for extenral wastegates. Basically, you buy that one and get it modded for whatever wastegate you want.
Cheuk, i might be pushing my luck here.. but hye it doesn't hurt to ask...
Will this manifold and downpipe work in a 1998 accent with a 2.0 installed?
thanks,
Denis
thanks,
Denis
I don't see why not, if its is the 2.0L Beta. Most systems do fine with the internal wastegate for the T025, T028, T3. 2 UNIQ's problems are most likely due to poor downpipe design of the Alpine unit.
I am still waiting on word about the cast manifold with the built in opening for a external wastegate.
Cheuk I am a little ocnfuse about something. HOw is alpine running 5psi on a internal wastegate?
I am asusming it modified for only 5psi?
Cause normally they are set for (t3) 9-11psi and for any other boost range you need a external waste gate. right?
so you should be bale ot take any internal wasetagte and mod it for 5psi?
