Car Idling Weird
how long have you had the car?
assuming it's a leak i'd start by spraying carb cleaner (at idle) around the intake manifold and intake air control/bypass hoses (enywhere where manifold vacuum is carried) and if you notice a rise in rpms you've found a vacuum leak that needs to be fixed.
done any recent work to the car lately?
this would raise my suspisions more to something being put back together wrong. Like any intake manifold/throttle body work, or air intake work? I doubt your intake air control valve is faulty (it would throw a Check Engine Light code I believe), but I had the same problem after installing my airram and rside throttle body.
to temporarily save yourself the embarresment at stop lights, you can loosen the idle screw on the throttle body to lower the rpms but that is NOT correcting the problem (it will actually create more for you down the road).
i have had the car for about 2 years and 40,000 miles or so. i was thinkin it might be the tps but ill have to look for a vacum leak just to see.and ive never have done any intake manifold work.
