Cant Get My Exhaust Cam To Move To Get Engine Tdc
I am trying to get my engine TDC and i am having troubles moving the exhaust cam to get the timing correct. I have pulled on the cam pretty hard and it will not budge. The plugs are out so compression shouldnt be a problem. I have asked a few people about it, someone said to crank the engine for a second so move the cams, i tried that and the cams still wont budge. Someone else said to just remove the brackets and take the cams off completely. I really want to get my engine TDC before removing the head, i dont know if im missing a step or something, i have never done this before and want to learn, so i haven't a clue if im not doing something correct.
Get someone that has testes to come help you out.
LOL
You can also get a big ass wrench and put it on the spot on the exhaust cam that's MADE for it. there are threads about it with pics, you'll see towards the right side of center there is a big hexed section of the cam.
LOL
yea i have been using that spot to try and move the cam, and ive pulled pretty damn hard too.... ive only had a crescent wrench once while trying to do it, because that the only tool i can find in my garage lol, that and a 17mm wrench....
ugh i knew i didnt do something....... no the car is in neutral lol.... haha
