Cams?
Actually...
Lift and duration will never hurt any car, and high duration cams are excellent for turbo cars. The problem isn't duration, it's overlap. If you have a huge amount of duration but a very small lobe seperation, then you will get lots of overlap and the turbo car will not perform as well.
The best cams to get for a turbo car have lots of duration, but a very wide lobe seperation as well.
-Red-
-Red-
2UNIQ is partially right. USUALLY the stock cam works as well or better than most "turbo" and definately better than most NA cams. But if you can find a good cam shop and designer, a long duration, high lift, MINIMAL overlap cam like RED mentioned is the way to go.
Vehicle: 2008 Accent
Right now I'll probably just remain N/A
I really don't see a turbo/super in my future, maybe NOS, but thats about it, would it be to my benefit to keep my old cams if I do decide to go NOS?
By the way how much are those HVE high duration cams?
And what kind of performance increase will I see with a mostly stock setup with new cams? I wouldn't be expecting much, I'd just like to put the groundwork in for a good N/A setup.
And my last question, which is off topic now, but it will sort of fit into the performance aspect of my car. If I don't decide to do a tranny swap to manual, what can I do to make my auto a stronger transmission?
Would either Elantra Beta intake cam be preferable to the 2.0L Tiburon cam?
