Cam timing
Guest
Posts: n/a
Cam timing
I did a search but still a little confused if this is possible on the betas. I would like to adjust my cam timing (not ignition timing although that would be nice). Now without a cam sproket is this possible? ie. just moving the intake cam 1 tooth to advance or retard it which ever is better? How much would this be in degrees? or do I advance both intake and exaust cams? Or can I just use the main timing belt? I was wondering if there is an advantage of doing this or not. Ideal situation would be that I can advance my timing without a piggy back like the ITC but if I understand it right there is no way to adjust the ignition timing on the betas due to the non adjustable crank position sensor which is where the ECU determines timing. Thanks.
