Cam Specs?
I received 2 CAMS? from the guy I brought my tiburon from and its an 01.. And he said there were custom made from CAT CAMS but I don't have the specs? I tried calling and they never answer? Is there any way I can get the specs for the cam? The guy moved acrossed the country this summer so I can't contact him
Vehicle: 2000 2.0lse Coupe/tiburon
Cat cams....
Inlet cam: 254 degree duration, 10.15mm lift
Exhaust cam: 248 degrees, 10.00mm lift.
valve overlap is 30 degrees.
i have more detail if you need it. ?
thats the specs for the NA spec cams. Cat Cams have 3 other profiles that are for turbo applications, which im afraid i dont know.
Aaron
Aaron
This reminds back in the day in 2002 when i tested a set for JRP here in Canada for these cams when i was N/A
I rememeber having only Intake,headers with exhaust and gained 14WHP on the dyno.These were defently lumpy cams when i had them in my car fing02.gif
did you just say you got 14whp from the catcams i just listed above?????
please tell me i read that right, as im fitting them this thursday! lol.
... and er, how lumpy?
thanks,
Aaron
thanks,
Aaron
I did a serach and found an old thread on the catcams stating a 14WHP gain without tunning at all...
http://www.hyundaiperformance.com/forums/n...37-catcams.html
Redzman: may i ask what those cam specs were please? and was that under a F/I or N/A setup?
2UNIQ: yea i found those threads, but i thought u said above ^ that you tested them yourself? in regards to the tuning of them, did you do fueling, timing, or both or neither?
i have just got the SMT-6 to use with them. but i cant find any resource to say what ECU work had been done/ not done to acheive this 14whp.
i have found a small list of mods, much like what you listed above, but no ECU stated, so does that mean they were effectively 'un-dialed' to make those gains?
thanks,
Aaron
thanks,
Aaron
I've got the specs posted somewhere, they are the KFX Peformance cams, we are looking for someone to get them and do a before and after TUNED dyno on them, info is posted.
They were nice in my car. Decent power and nice smooth idle. I did end up wishing I had gone with something bigger. Maybe some 264's.
QUOTE (EnglishTib @ Sep 29 2008, 01:19 PM)
thanks,
Aaron
thanks,
Aaron
I did have a SAFC at the time but was never tuned just installed on the car and ran it.Also at the time i tested the cams i was Auto and then coverted to 5 speed...
